dt4134
Inspired by the recent threads on shorepower I had a quick check. There's about 2.9V between the Neutral and Earth within the boat (that is at a point where it is easy for me to use the multimeter safely to make the measurements which is actually at the junction box for the input to the shorepower unit, so after the RCD).
Anyway a bit of an inspection shows that some bits of copper wire have a black coating, presumably copper oxide. I've a few bits of spare tinned mains cable that I can use to replace some of the shorter sections, but I don't want to get involved in a major project so I need to clean some of the other bits. Sandpaper is a bit hit and miss on multi-core cable.
So the question is, is there an easy chemical way of removing the copper oxide so I can use a soldering iron to tin the ends of the copper wire?
