Tranona
How do you manage without a shackle? How do you remove the halyard when you drop the main or change the foresail? I use a halyard knot onto the shackle; the hoist line on the mast leaves enough room for that.
The only way to remove a halyard knot after using it for a while is to cut it off I find.
Also, a splice may struggle to go over the sheave at the masthead if the halyard is generously-sized?
If you regularly remove the halyard from the sail then there is an argument for having a shackle, but on a furling genoa for example a knot is OK. On a mainsail there is no real need to detach the halyard every time if you can take a bight over to a cleat so that you tie it clear of the mast to prevent it bashing.
