jerry098
Hi all,
I'm in the process of separating the starting and domestic circuits on my M27.
Would anyone care to look at the very rough circuit diagram attached and advise if it looks OK?
In this process I will be adding a new dedicated starting battery and was looking at a Odyssey PC680 - however I have some questions:
1. I have, already, a Sterling battery to battery charger. From the description of how it works it apparently drops the alternator charging voltage at the starter battery to 13V but the advised minimum charging voltage for a Odyssey battery is more than 14.2V.
Does this mean I can't use a Odyssey battery with the Sterling B to B charger?
2. If I can do you think that the Odyssey PC680 will have sufficient grunt to start my 25 year old Volvo 2002 (18hp)?
3. Do you think the output from the solar regulator should go to the domestic bank or the starter battery and thus to the domestic bank via the Sterling B to B charger?
All advise appreciated.
