Removal of Trackmark
sailorman
21 May 2003
Here or thertemp ashore
I have to remove 2 sections 500 x 200 from my cockpit. This is glued down.
What is the best way to remove the adhesive pls. heat gun ????
the replacement is the self adhesive type
Tia
rogerthebodger
3 Nov 2001
Do you mean trekmark or treadmaster these are two different products that do the same.
The guys who clean the outside of my boat are making a very good attempt of removing my treadmaster with their high pressure washer.
Tranona
10 Nov 2007
Treadmaster is the new material i assume the existing is the same
If it was attached with the proper adhesive, be prepared for some hard work. chisel, angle grinder and sand off the residue. Heat does not work and don't know of any solvent. Dreadful stuff and difficult to lay on anything but a flat level surface.
Only consolation is that if you do the job properly it will probably outlast you and you can look up (or down) at the subsequent owner cursing you as he tries to remove it!
sailorman
21 May 2003
The existing stuff is utter rubbish. It has only lasted 35 years :disgust:.
The Lady @ Tilflex agreed, when i told her :D
Tranona
10 Nov 2007
Yes, I know it lasts, but you won't be so kind about it when you try to get it off - although you only have little bits so won't be too painful. I have unhappy memories of stripping a Centaur and then trying to get the new stuff to stay stuck to the curved coachroof.
sailorman
21 May 2003
fortunately on flat topped combings, these get a lot of wear as one stands on them on entering / leaving the cockpit
