Removal of raw water pump on VP 2003 engine: is it dead easy, even for an engineering numpty?
I hope the workshop Manual has some into
I have never seen the manual as I usually just get involved when folk at the marina get stuck. I then explain the logical process and together we sort it. there are some parts of the system that if you jump a step then only brute force might get the pipe into place if you have put something back prematurely. When done correctly everything slips into place and is secure .
The original question was in regard to the water pump. The connections are in line and opposite sides of the body. If the pump is difficult to remove then it may be necessary to remove another item in line to free the pipes.
Here is the manual for general help. Page 39 covers some of this.
https://ab-marineservice.com/wp-content/uploads/2021/01/VOLVO_2003WORKSHOPMANUAL.pdf
