K-ron
Hi,
A couple of questions:
1. Will the bearings drift out using those small recesses in either crank shaft web? There are corresponding recesses on the opposing side of the webs, or are they to accept the arms of a puller (which I don't have)?
I have given them a reasonable whack with a 1/2" brass drift to no effect. I have new replacement bearings so I could butcher the cage and apply some heat?
2. How should I install the new bearings? Tap them on with 1/4" drift on the inner race? heat them in oil on the hob first?
3. Finally the big end roller bearing has axial movement of 0.65mm which I presume is between the internal and external races and radial runout (perpendicular play) of about 0.3mm is this within tolerance? The manual doesn't specify.
Many thanks for your thoughts.
Kieran
Kieran
