Scholesy
New Member
Hi, thank you. Does this work in conjunction with the 801 controller or separately? Thanks. JS
I’m using the Quark elec G022 and it’s brilliant.
One output controls the Mikuni heating (eberspacher equivalent).
One output controls the generator auto start.
One output controls deck lights.
One alarm input connected to bilge pumps.
One alarm input monitoring the shore power supply.
I have the GPS version so I can also poll my boat for its position - not massively useful in a marina setting, it good to keep an eye on where the boat is if we step off at an anchorage.
Nothing better than returning to the boat on a cold winters night, moored away from base to have the deck lights on welcoming me onto a warm boat, with the gennie running and heating the water and charging the batteries. Worth every penny in my book!
I have also just partially installed another G022 in a friends boat - eberspacher connected and working, other wiring runs still to be completed for the other features.
Great bit of kit!
I've only just spotted this thread and am interested in the remote operation of various systems on board and like yourself want to be able to switch deck and interior lights remotely and a GSM switch of some sort is the obvious answer. I've just looked at the Quark-Elec unit which look just right.
I'm interested in your 'auto start' generator and how you start it? I have a 12kv Northern Lights unit which requires me to press an overide button whilst pressing the start button and I'm not sure how I could do this remotely?
Cheers
Andy
Wouldn't you just wire a 2 pole relay so that the two circuits are separately closed, and then just control that relay from whatever remote device you've selected?
https://www.deepseaplc.com/genset/manual-auto-start-control-modules/dse3110
Got one of these controlling the gennie.
It can involve some complex rewiring, but a good spark should be able to figure it out.
Comes with loads of configurable timers and switched outputs - mine is set to inhibit water heater and battery charger when the boat is running on the inverter. The water heater and batt charger come on automatically when the generator is on line and supplying power.
Ebay is your friend...… Will this work on those overpriced cartel heaters
https://www.ebay.co.uk/itm/12V-LCD-...012070?hash=item41f9559e26:g:ClUAAOSwPjNcZjHV
Or you could replace the whole think for £140
https://www.ebay.co.uk/itm/UK-5000W...586045?hash=item23a2d2e6fd:g:83wAAOSwHQdcb2CD
What you've suggested isn't really the type of kit I'm looking for.
I'm looking to set up a system on board that will allow me to control various items, such as the generator, internal lighting, external lighting, heating and hot water etc. from a remote location via SMS.
So, for example, if we're anchored up somewhere and ashore in the dinghy then I can make sure the lights are on and have hot water ready etc for when we get back on board.
Or going to the boat in the marina during the winter, I can turn everything on before I leave home.
Cheers
Andy
Sorry I misunderstood
Thanks for that. I'll have a good look at it but at first glance it looks like just the thing.
Am I right in saying you use a seperate GSM switch to control the DSE3110?
Andy
Thank you. Does the yellow (switch) wire come from the heater loom to the GSM or the yellow wire from the 801 controller? JS
