northwind
I have an aluminium rudder stock, attached to the boat with stainless steel brackets and bolts..
It needs some tlc, I plan on stripping it down, removing the paint and starting from scratch.
The aluminium and the lower gudgeon have of course been fizzing away in salt water, so there is a bit of corrosion; does this need treating? or can I just remove the fittings, apply etch primer, and then use some Tef-gel when I reassemble?
Is there anything else I can do to keep the galvanic corrosion at bay?
