rascacio
Hi all, I have a bit of a problem with my fridge. It goes like this, it's a Waeco Coolmatic RSA-110 with an accumulator plate and the TEC control unit, however with the TEC unit I find that within an hour or so of running off fully charged batteries the unit shuts down and the yellow voltage light flashes.
The battery voltage measured at the unit is still showing 12.5v but the unit will not run unless the engine or shore power is back on.
The blurb on site says the switch off voltage is 10.4v and the switch on is 11.7v. My batteries are well above this but it just doesn't work.
Has anyone experience with this TEC unit and also can I simply get rid of it and use a normal type of thermostat, which I had with my old system ?
Maybe the TEC unit is knackered but any info from anyone who has or has had one of these would be much appreciated.
By the way this is a used unit that was not very old when I got it, it was being changed for a watercooled system., and works flawlessly on shore power and a fixed voltage of 13.5 volts.
