ian38_39
True, for one thing there would only need to be one meeting and one vote. This would impact heavily on the expenses claims of the MEP's so you are right. A totally ridiculous idea.
Yes you are. You are breaking the directive that says you cannot use marked (red) fuel. That's what the current issue is all about, nothing to do with duty or the 60/40 split.
Years ago, I actually read the directive as there was so much blx talked about it, but I confess I cant be bothered to read it again ....I did try a search on here, but cant find the relevent posts.Yes you are. You are breaking the directive that says you cannot use marked (red) fuel. That's what the current issue is all about, nothing to do with duty or the 60/40 split.
there is nothing at all to stop you buying fuel at a lower rate than UK road fuel.
I am pretty sure the directive relates to use of dyed fuel and propulsion.
But you are saying that if you put in red at full duty for propulsion, you are still on the wrong side of the directive?
Exactly the same opportunity still exists with green given that it would be marine fuel with no bio. Road fuel must have bio.
It is I beleive UK gov that won't apply different rates. If I am right the only requirement from Europe is that the minimum dity is applied, happy to be corrected.
If diesel boaters are heading for a 50% hike in fuel costs (and I think the politics are driving us towards that), what will result?
To keep things in perspective, 50% is very much an exaggeration. Yesterday the difference in price between white marine diesel (which nobody sells yet) and red diesel with 60% duty added was 19p per litre. Hence the cost would go from approx £1.15p to approx £1.35.
Where are you getting your white from for £1.35 ?
Marinas here are charging close to £1.50 for red.
Regarding perspective, how about taking a global one (prices in US cents per litre): http://chartsbin.com/view/1128
Spot the Eurozone (ironically the colour of red diesel!) we must all be doing so terribly well for ourselves to be able to afford such massive taxation?
Where is 'here' to you?
Red on the South Coast sells at 85p/litre before duty, £1.35 after at 100% duty, £1.15 at 60%
The price of white out of the refinery pre duty is currently within a penny of red.
As I said the directive stated that we could not charge a different rate of duty for the same fuel.
QUOTE]
I dont think that is correct. I think the directive says that a country cannot have different taxations levels for the same fuel for the same use.
IE fuel for heating can be taxed differently from propulsion, but propulsion is propulsion.
