recover C.D. data NB
sailorman
21 May 2003
temp ashore, i expect to be back🤞
Hi all
i have many photos on a CD that i cant recover / read for some reason.
i have tried Roxio scan-disc utility (the files were written via Roxio)
any help welcome
roger
<hr width=100% size=1>Mines a Crocodile sandwich & make it Snappy
Roger, you could try this:
http://www.downseek.com/download/21707.asp
I have not tried it myself so can give no recommendation.
Good luck.
often had problems reading CDs which were cured by using a different PC. i think there can be problems with tracking accuracy.
Try using a new cd rom. I have often found that older cd roms are not very reliable reading home made cds. Try burning a copy (long shot).
Tip for the future Don't use rewritable CD to store data pics etc as they are not as reliable as the burn once type. Also for reliable backups burn at least 2 cds.
Here is an interseting page on the subject
http://www.luminous-landscape.com/essays/image_security.shtml
Sorry can't be more help
Colin
<hr width=100% size=1><A target="_blank" HREF=http://www.iol.ie/~colinl>http://www.iol.ie/~colinl</A>
i am older + wiser now.
i thought i had discarded a cd but think one cd is / must be Corrupt & only showing about a 1/3 of the data
i have downloaded a number of programmes & am sure the data is there
thanks for your help
roger
The Life span of a CD is surprisingly small. Sounds like you have some CD's starting to degrade. I know we were all sold CD's on the premise that they would last forever. But it's simply not true. Every CD I have seen that is 10 years old show some kind of degradation. Audio CD's kept in the home can have degradation but still play. The player skips the errors and we can't hear the difference until it gets really bad. Data CD's show degradation much more readily, because one error on the disc can result in a program/data failure. On top of all that, CD's kept on a damp boat will degrade even faster as will CD's created on a home burner that is of a lesser quality than very expensive commercial ones.
My advice is this. Wherever data is very important, keep it on a hard drive. Hard drives are cheap these days. Also as new data storage technologies become available move your data on to them.
A recent survey by the Dutch magazine PC-Active on 30 brands of CDR has shown the life expectancy to be only 20 months!! However some of the better branded CDR's have done a lot better.
Type CD degradation into your search engine. There are many forums discussing this.
<hr width=100% size=1>Stoaty
Hi Dave & welcome
i have been very good at completely b****ksing-up my PC i have tended to store data / photos on CDs as i assummed they were "safe". well yer pays to learn.
i hope these photos can be retreived as they were mainly of the 2003 season.
we sawabout 10 Dolphin on the trip from Harwich to Ijmuiden roughly 1/2 way accross & took many photos.
fingers x
& thanks
roger
Roger, have a look at the surface of the CD. Is it scratched, or are any areas of different colour?
There was a thread a while back on CD/DVD viability as long term storage you might want to read to give some perspective
<hr width=100% size=1>NesQuid agis, medice?
Hi Brendan
the disc does have very light scratches.
no different colours.
but the disc has been recorded in 2 distinct sectors with a small band of approx 1m/m ( of un-recorded disc ) in between.
the disc is recorded out to about 1/2 disc width
roger
Scratches on the surface can have a huge impact. There are devices available to take these off. Might be worth trying as a last resort if you've tried other CD players first, and these also cannot read the disc. A one or twice off option only though, as they cut through the surface (like over sanding teak) eventually
There is no protocol that necessarily gives access to any CD player, it depends on the format of the player/writer you have, and the software you used to burn it. Some info on this would help.
LG Roxio 5 running an LG re-writer.
i can read what i think is "part of the disc" every time, the system scan-disc tells me there is a problem but cant fix it. i cant "close " the disc either.
i have formatted another disc to drag-drop & that works fine & would "close" if required.
i have copied all the photos that were accessable, assume there r more
roger
]Mines a Crocodile sandwich & make it Snappy<P ID="edit"><FONT SIZE=-1>Edited by sailorman on 20/12/2004 06:52 (server time).</FONT></P>
