recommended bedding compound/sealant for port lights
pcatterall
2 Aug 2004
Home East Lancashire boat Spain
The old compound is cracked and leaks on several windows.
I re-bedded one with that (butyle?) stuff that comes on a tape backing and has been great for deck fittings.
Even in the warm med I found it a bit too stiff so the layer of bedding is thicker than I wanted ( it doesn't leak but doesn't look too good!)
What is the recommendation for this task please will it have a decent shelf life when opened or do we have to tackle them all together?
Butyl sealant in a cartridge, such as http://www.arbo.co.uk/arbo-sealants/arbomast-br/
Gets messy if you let it get out of control, cleans up easily with automotive panel wipe.
I've used the butyl glazing tape as used in window glazing. Had some left over from building an extension in 2012 and it's still in good condition. Used in re-bedding Aluminium window frames onto the grp. Also used for bedding in skin fittings. Excellent stuff and not at 'Marine' prices. I got it from Reddiseals.com
Butyl tape works well, but you must learn how to use it properly. You apply it, then compress it, wait a few hours, then tighten further, repeat. The surplus will slowly ooze out and after a few days you can then cut off the squeeze-out. It never sets. It's a multi-day process and is unsuitable for anywhere with an exposed edge, as the edge will attract dirt and look icky soon. It does create an excellent seal that can cope with thermal expansion and even slight movement.
Neoprene gaskets or tape work well too and are used in production boats where nobody has the time to deal with the above procedure. My portlights and hatches from 2001 were all bedded with some kind of foam gasket and none of them leak.
