Recommendations for Spares
Novice
22 Sep 2003
Sorry, me again.
So far I've got the following on the spares list:-
Oil filter
Fuel filter elements
Seawater pump impeller
Insulated electrical wire
Grease for stern gland
Oil for engine
Alternator belt
Any further suggestions would be gratefully received - the boat is a Sun Odyssey 32 with a Yanmar 2GM20 engine.
Thanks for the help on the tools, and tcm, I'm not carrying a spare short engine.
<hr width=100% size=1><P ID="edit"><FONT SIZE=-1>Edited by Novice on 10/03/2004 20:37 (server time).</FONT></P>
VicMallows
25 Nov 2003
Emsworth, Chichester Hbr, UK
Lots and lots of stainless nuts/screw etc. in every likely size.
All sorts of electrical bits. Definately spare alternator. At least brushes for the starter motor.
Shackles in all sizes and cramp-clamps etc. Spare rigging wire.
Plenty of scrap metal (ideally stainless). Lots of hose in as many forms as possible. Everything you've ever replaced.
Tools, tools, tools.
Sorry, list goes on and on, and boat gets heavier.
Vic
sailorman
21 May 2003
Here or thertemp ashore
various hose clips
block connectors (various)
"instant" gasket-goo
5 lts fuel in can
engine anode
spares kit for all pumps o/board
self amalgamating tape (Hose repair)
electricial tape
ongolo
5 Aug 2003
Spare cyl head, spare fuel pump, spare injection pump, set of injectors,
One spare new battery dry with acid kept loose to fill batery when new battery is needed, should be serviceable in less than one hour after filling
spare nav light bulbs, spare light bulbe for cabins ect
spare chain/cable or whatever makes up you steering system
regrds ongolo
<hr width=100% size=1>1000 dream about it, 100 talk about it, 10 start and 1 completes it
boatless
1 Mar 2004
What, you've still got money left after buying the toolkit? Blimey.
Sail repair kit, spinnaker repair tape for quick fix on any sail.
A spare full length mainsl batten.
Corkscrew.
BrendanS
11 Jun 2002
Tesla in Space
you could always take a whole spare engine! Might be a good idea for blue water cruising, but not an essential spare round Europe.
<hr width=100% size=1>Utinam logica falsa tuam philisophiam totam suffodiant
Col
14 Oct 2001
Berks
I carry
4 sets of fuel filters
2 impellors
2 set of belts (alternator, waterpump etc:)
2 spare thermostats
engine oil
gaffer tape
Various diameters of engine hoses in meter lengths.
Various tubes of sealants and gasket goo.
Other stuff that I can't remember now
<hr width=100% size=1><A target="_blank" HREF=http://www.arweb.co.uk/argallery/colspics> Cols Picture Album</A>
BrendanS
11 Jun 2002
Tesla in Space
more suited to small mobo's but would add spare prop, tab washer and nut (and spanner)
Rohorn
3 Oct 2003
Paros, Greece
and other necessities such as,
--an old car inner tube with a pair of scissors for making the seal or gasket you forgot
-- a single strand from heavy rigging cable or metal coat hanger for poking into holes and water passages
--- a plastic bag marked plastic baggery for all the plastic bags you accumulate
-- schnorkel and mask for use when clearing prop..preferably with wet suit top
-- tube of silicone grease..or several 'cos they disappear quickly
-- battery acid test syringe for clearing blocked ears after clearing prop
-- electric loud hailer with built-in translator to Greek argot
You may consider selling the leatherman clone or huge Swiss army knife donated by well meaning relative. If you fall heavily with one of those in your pocket, it won't be funny. I know.
Cheers....R
DanTribe
8 Jan 2002
Essex
Spare mast & rigging, spare anvil, spare Sun Odyssey hull to tow behind to carry all the spares recomended by others. Oh, and spare wallet with spare credit cards.
extravert
20 Jun 2001
Not far from Uwchmynydd, near Bwlchtocyn, just up
If you took everything suggested here, and responses to similar questions, you would be in danger of having a cluttered heavy boat that sailed like a slug. So I am going to say the opposite. You are probably not going to be sailing across oceans or around continents, so you should keep the clutter down to something more appropriate to the sailing you are going to do and the size of boat you sail. Of course take a basic set of tools and spares, but avoid filling up your boat with equipment that you will never use, because 1) it is expensive 2) it gets in the way 3) it will deterioate.
So in addition to the engine spares you have mentioned, I take the following collection of spares...
A few shackles of various sizes
2 snatch blocks
A few bulldog wire clamps
A handful of different nuts, bolts, washers and self tappers
A dozen cable ties
A few chocolate box electrical connectors
Sewing/whipping twine
Sail patches
Light bulbs and fuses
Some cable ties
A few jubilee clips
Insulating and self-amalgamating tape
Assorted bits of rope, cord, shock cord and tape
Epoxy and impact adhesives
A full length batten that can be cut to required length
A section of old inner tube for cutting seals and gaskets
A spare cleat handle
A few spare sail slugs (when I had a sail that used that system)
A small tube of gelcoat repair
Set of emergency navigation lights
Spare batteries suitable for the equipment that uses them
If it helps, I have listed the problems encountered on a 2000 mile coastal trip I did in 2001 <A target="_blank" HREF=http://www.xrayted.fsnet.co.uk/whatwentwrong.html>here</A>.
<hr width=100% size=1>One day, I want to be a real sailor. In the mean time I'll just keep trying.
snowleopard
Oxford
this thread has got a bit silly. next thing it'll be a spare boat you can cannibalize for spares.
at the other extreme, one of the french s/handed racers would only take a mole wrench and a screwdriver on the basis that anything he couldn't fix with those meant he was out of the race anyway.
the big question is how far are you going? if it's likely to take you far off the beaten track the one spare i'd advise above all others is an alternator. if you're usually within reach of a chandler then what you need is to make up the kit that every seasoned sailor has acquired over the years-
spare shackles, pins, tape, string, glue, half-used tubes of sealant, wd40, bags of assorted bolts, nuts & screws, odd lengths of rope, dinghy patches, offcuts of wood, metal, plastic etc.
and you can be sure that however many spares you take, in every port you'll be in a chandlery looking for something!
ongolo
5 Aug 2003
Who says I have a Volvo???
ongolo :)))
