Recommendation for prop repair?
seanfoster
5 Jan 2006
Nottinghamshire
tridentcanvas.co.uk
Hi All,
Following on from a previous thread, I'm going to send my VP duoprops for repair due to blade damage, from searching the web I found Steel Developments based in London, Castle Marine in Caernarfon and Streamline Propellers in Linconshire.
Has anyone got any recommendations for any of the above, or anyone else?
My props are in pretty rough shape, particlarly the front one of the two!
Castle Marine. When it comes to prop repair their rep is world wide. Literally, walk in and you'll see props sent in from as far as South Africa and all over Europe. Had mine redone there, superb job. You wouldn't believe it visiting the place. A ramshackle barn on the banks of the Seiont. If I hadn't seen the Vincent factory in even worse lodgings on Bridgewater canal or Polymarine off the back of a service station I'd have written it off. What is it with Brit old skool skills whose rep is hallowed world wide always found in some derelict shed?
Cheap rent?!
I recent years I have been better at not hitting things with the props .
But I have used Streamlined a few times . A one man business (unless something has changed in the last couple of years) .
Hi All,
One other company you could try if stuck is Clements Engineering near Bedford.
