gregcope
Hi
What alternatives are there to an Anderson plug (SB50/SB175)? For example the dinghy inflator I have seems to pull quite allot of Amps judging from the temp the cables get to. It uses crock clips to the battery terminals, which is okay but not ideal. To access my batteries I have to clear stuff+Cushions+open locker. I am very careful not to short anything when connecting them and you end up with a cable through the boat. It is easy to pull it off the batteries when moving it.
12V car sockets have similar issues. Our tiny inverter which seems to warm up the 12V sockets quite a bit when running a vac in the past.
So I would like to wire in some suitable plugs. I am leaning towards an Anderson plug on a long flying lead I can drag out of a locker (more easily) or wire some in the forepeak and stb cockpit locker. Then add Anderson plugs to my high amperage things (like the inflator, crash pump, tiny inverter). The thing preventing me from doing that is that Anderson plugs not offer much protection from the elements and is there a better solution?
Any other suggestions? Or should I just go Anderson and be done with it?
