haydude
I was wondering if a crew member has a PLB and activates it in case of falling overboard, how would we be able to home on the PLB? Can only rescue services receive the homing signal on 121.5MHz?
What you need is an old RDF unit with a swivel mounted aerial on top!
And an old navigator mounted underneath...![]()
I thought, but may be wrong, that nobody monitors 121.5 any more so use as a personal beacon other than as a MOB device might be wasted?
The reason for my query was because I am considering the purchase of a PLB. PLB will broadcast the emergency call to satellite, but also send an homing signal on 121.5MHz.
It does not really matter if 121.5MHz is remotely monitored, what matters is that if I loose a crew member overboard 100nm from land, and he has a PLB I would like to get to the MOB first and ASAP and an homing signal receiver would be essential.
So how do I get hold of one? That is because a PLB makes lesser sense if the only ones receiving the emergency call are far away emergency services who might not be able to contact me to tell me the MOB position because I am beyond VHF reception range.
Since I understand that in order to receive a PLB homing signal one should have special equipment, it would make more sense if these PLBs also broadcasted their position on DSC or AIS VHF.
As an RNLI crew member i can assure you the 121.5 is still monitored. All RNLI all weather lifeboats carry direction finding radio equipment that can home in on 121.5 as do all SAR (search and rescue) aircraft.
Commercial aircraft also monitor this freq though they can't normally home in on it, but would normally alert the emergency services who have this capability.
DSC is not a suitable replacment for PLB's wether it has position polling or not. We cannot home in on a DSC signal as we require a constant RF transmission. PLB's will take you to the MOB's current position where as DSC will take you to the last transmitted position which could be miles away dependant upon Weather and tides.
PLB's and 121.5 is still (and will for some time) be a very important part of GMDSS.
Have you looked at the RNLI's MOB Guardian system, it is designed more with the single handed fisherman in mind but still very relevant.
http://www.rnli.org.uk/mob_guardian/
IIRC Hams have hare and hounds events when they use their home-made DF aerials to locate a signal. Do we have any Hams who'd like to knock up a set based on a 121.5 crystal? Receive only, so no licensing problems...
Rob.
