steve yates
I have a lofrans kobra anchor winch on my longbow for 8mm chain. It’s 1000w and the specs say can draw 150a. It was wired to the house bank with 35mm welding cable and a 100a circuit breaker. The cable run for was 7m one way.
All well & good, in use the breaker only ever tripped once, and that may have been because I decided to sail off the anchor & hadn’t started the engine iirc.
Now I’m rewiring the boat, looking at possible locations for a seperate AGM engine/winch battery from the new lifepo4 house bank. Cable runs vary from 6.7m to 9.5m depending on practicality of final location, and I have 50mm tinned oceanflex to replace the welding cable.
Imagine my surprise when I ran victrons voltage drop calculation app and it said the % loss with 35mm would be between 10.2 and 14.4! And for 50mm still 7.5- 10.6!
I can’t imagine going to 95 or 120mm cable on a 31ft boat, so what am I missing here?
Is it because running the engine lets the alternator ido a lot of the heavy work?
Or is it just a case of theoretical perfection is impractical or unobtainable?
I’m now thinking I might let sleeping dogs lie and see if it still works when she is recommissioned
I’m curious.
Edited to add: Bloody hell, just seen the prices of lofrans 100a breaker, £250, more than all the cable cost!
Are there alternatives at better prices, in case I chucked the old one out when stripping the boat out
I’m curious.
