Re-finish Cabin Sole
Talbot
23 Aug 2003
Brighton, UK
My cabin sole is the standard wood with white insert that is widely fitted in the industry, but new to me. The finish is dull but grips well to the shoe. I am in the middle of a major refit, and wondered what I ought to do to this flooring. I do not even know what it has been finished with - oil or varnish.
So some advice please.
It's probably teak veneer with holly stripes.
To remove the old finish if it is varnish then use a stripper like Notromors and scrape it off. Gently on the sanding.
I use Ronseal Diamond Hard floor varnish in clear satin. Easy to use and lasts several years. Easy to go over without a complete strip. Not slippy
I have used Ronseal Diamond hard, not the finish of a good varnish but hard wearing, fairly good non slip. it does end up with some brush marks but not that obvious.
it is a water based product for household timber floors, dries quickly ( hence brush marks) easy to over coat nxt time
It is actually wood, I take it? Mine turned out to be teak-and-holly-effect plastic laminate over plywood. I only mention it because the "dull but grippy" finish sounded familiar.
If it is wood, I find that wiping it over with a tiny amount of teak oil, allowing it to soak for a couple of hours, then rubbing off all excess oil with kitchen paper, leaves a good practical finish which is easily maintained. I certainly wouldn't varnish it.
If the sole is looking a bit jaded, I add a very small amount of dark "scratch cover" to the teak oil before applying. This helps to restore the teak colour.
Robbins Timber do a laminate sheet which is really durable and looks good. Also if not recoverable, I have used TEK DEK with excellent results on my lil' boat......
