Re-bedding / sealing deck fittings
Big-Bang1
5 Aug 2013
I know this has probably been done to death but... I have a Channel Island 22 with leaks. The grab handles on the cabin roof and VHF aerial base are weeping water in. I've dropped the headlining ready but don't know what sealant would be best. I've been advised to use everything from CT1 to No more nails 🤔
What do people use?
Personally I would not use an adhesive sealant which CT1 and No More Nails are. Review this article which is about sealing deck items. Bedding Deck Hardware With Bed-IT Tape - Marine How To
The buy some butyl sealing tape (which Bed-It Tape is) in the UK (I assume you are based here) and mould to the desired shape as per the instructions in the Marine How To article.
This butyl tape would do the trick, but search around for a good price PSP Tapes Butyl Sealant Tape
Another tip - after refitting don't fully tighten down the fitting straight away- it will probably squeeze all the sealant out- leave it to harden off a bit before final tightening
