Raystar 120 GPS antenna failed?
Nauti Fox
28 Oct 2003
Kent
www.facebook.com
I know these have a limited life but up until now it's always given me a fix, albeit it can take a while.
Now when turned on using an RC631 plus plotter I just get a blank satellite screen, it's not searching.
Could this be related to the rollover or has it had its day? If so can anyone recommend a replacement.
Sorry, I know very little of the way these are connected, the Raystar is badged seatalk, so unless there were good instructions I wouldn't know where to start..and with the Digital Yachts adapter I can just connect into the original wiring
OK, the Evermore outputs GPS data in NMEA format. Your plotter can accept NMEA data via its power/data cable - details in the manual.
Thanks for your help, although I might stick with the Digital Yachts setup as the antenna is on the fly bridge and there's also a RL80C unit up there and the wiring is virtually untraceable, even when I'm upside down, not a great position when your in your sixties!
Also the autopilot and VHF are linked in.
I know its probably an easy solution using nmea but if I can just disconnect the wires from the Raystar and connect from the adapter.....
I really do appreciate you taking the time.
Have you ever changed the battery in the Raystar? Certainly they take much longer to get a fix as the battery runs down but I'm just wondering whether they give up searching entirely once the battery is totally exhausted.
Just a thought.
Richard
The Raystar 120 wasn't one of Raymarine's greatest achievements, mine failed completely after about 5 years.
Hardly something to complain about - 5 years service for something mounted outside in the elements... Wind, rain, UV, ice, snow, etc...
But I do think it's unsatisfactory, products should be designed to cope with the elements, and 5 years outside is nothing. If the door mirrors on your car needed replacing after 5 years I reckon you'd be miffed.
