Raymic problem - Gosport
Ripster
20 Oct 2008
Torbay
I have a Raymic A46052, only about 2 yrs old, that has this season decided not to work. The main VHF unit all works fine and transmits and receives as it should - I have tested it. The Raymic at the helm was fine last summer, but for some reason over the winter, first lost its ability to transmit, but now is dead completely. When the transmit began to play up, I removed it from the boat and brought it home to dry it out and warm it up (thought moisture ingress maybe the issue). Having tested it again today, its dead - nothing. I have checked the plug and socket and all appear normal and in good nick. Before I start tearing the boat apart to check the wiring, I was hoping that someone might have a Raymic set-up in Gosport, so I could plug mine in and see if it worked? Just to find out whether I have a cable/wiring issue or a dead unit for sure.
Can anyone help :)
