wizzer
I am working on my "new" Seaward 25, she's a 2005 boat and has had very little use. The electronics package is Raymarine, based around a C80 MFD. The speaker for the Ray240 DSC VHF, was not working, now replaced with a brand new speaker. The DSM300 sounder works good, the plotter works good. The radar scanner, type 92650-S was corroded inside and is apparently dead. So, I bought a used one, in good faith, from Gumtree. It arrived looking good inside & out, when I connected it, the scanner rotated as it should and the radar picture appeared. However, after a few rotations, the radar image was lost, to come back again perhaps a minute later, this is what happens continually. I've been in touch with Raymarine technical support & the bloke reckons the scanner could be at fault. He went through some diagnostics with me. I have tried the same scanner today with a different cable, same result, image comes and goes. I have one thing left to try, updating the C80s software, I'll try that tomorrow, if I can find a CF card.
If I can't get this radar scanner to work, I'm £300 down so far as the Gumtree seller seems convinced the radome was OK when he posted it. If that's how it is to be, then I need to decide whether to pay out more for another used scanner, maybe an RD218, or to give up on the old radar and get a stand alone radar and display to run alongside the C80 MFD running the depth sounder and plotter.
Comments welcomed, cheers.
