Nigelb
In that case, why do you show ethernet cables going into it?
Good spot, I have confused the two schemes or options, the cable harness supplied with the Element unit has a combined connector for Power and NMEA 2000. The adapter was to connect this NMEA2000 connector directly to the Seatalk Ng backbone, assuming that the HS switch is redundant and removed from the system.
Thanks.
