Raymarine Hybrid Touch Plotter 2014 model
Nigel52
21 Nov 2021
Has anyone got a Raymarine Hybrid touch chart plotter 2014 model and has fitted ais to it? If so what module, was it easy to fit. I’m looking for the least expensive option to fit AIS to appear on the Raymarine screen. I’m talking about a rx & tx version and what aerial did you use or did share the vhf aerial?
Boathook
5 Oct 2001
Surrey & boat in Dorset.
I fitted and connected the raymarine 700 ? AIS that has a built in splitter and it's own GPS aerial to my eS9 plotter using the seatalk ng network. Once the AIS is programmed (you need to do this for it to transmit) it was plug and play so to speak.
I believe that an emtrak model is very similar and that Raymarine use it and rebadge.
PaulRainbow
16 May 2016
Suffolk
This is correct.
PaulRainbow
16 May 2016
Suffolk
Great, do you know which emtrak model is compatible? Vhf splitter is useful.
All Emtrak B9xx models are compatible, as are pretty much every other AIS.
The Emtrak B923 is the least expensive model with a built in splitter. The B953 is the more powerful SOTDMA version, which costs a little more.
Nigel52
21 Nov 2021
When I go on the EM-TRAC website it recommends the B923 for what I wanted. However, I will also look at the B953. This is a 2025 project.
oldgit
6 Nov 2001
Medway
When on my Hybrid plotter the installed splitter stopped working the quickest simplest and cheapest solution was to install a separate antenna for the AIS unit.
Any ordinary Marine VHF will do the job.
Nigel52
21 Nov 2021
That is interesting as I was considering installing a separate external GPS antenna. If I install a separate AIS/VHF aerial I might consider a cheaper AIS without the inbuilt splitter. I guess for ease of installation NMEA 2000 would be better for interfacing a Raymarine Hybrid plotter than NMEA 0183.
PaulRainbow
16 May 2016
Suffolk
The cheapest Emtrak without the splitter is the B923. All of the B9xx series have NMEA 200 and 0183. If you have a N2K network it's simple to add a tee and a drop cable, if not, it's simple enough to connect the 2 x 0183 wires that are needed and this option costs nothing.
Nigel52
21 Nov 2021
Totally agree and I like the EM_TRAC series of AIS Transponders. tee & drop NMEA 2000 I think is the best.
