Raymarine Dragonfly transducer
gjgm
14 Mar 2002
London
After the highlight elsewhere on the Cactus deal on the 6, I see it comes with an external transom transducer. Anyone know if this Chirp type will work mounted inside the hull-Raymarine seem very non commital. I know typical Airmar one will work in the water bath in hull, but I am not sure these Chirp ones are as powerful.
Mind you, not a bad deal just for a plotter.
Anyone tried it?
From the limited research I did on this the transducer is the size of a sausage and hinges up / down. I would very much doubt you could mount this internally.
Again from my limited reading the transducer works on 2 frequencies and each fan out to different degrees - so it not a simple ping!
Raymarine do not sell an inhale transducer
http://www.raymarine.co.uk/view/?id=6854
so I suspect it won't work. The oil bath transducers are always a bit work or not, and this is far more specialised.
Thanks, I was also doubtful; I guess Chirp is a bit more low speed fishing stuff than a basic depth reading.
Still, quite neat just as a small plotter.
