rjmcl
Hi, my Jeanneau 45 (in Greece) was struck by lightning, and I am replacing all existing defective Raymarine electronics.
Yacht is 2008 and has twin wheels. Initial plan was to install Axiom 9 MFD at chart-table and an i50 Tridata and i60 wind display at each of the helms. Basically replacing my existing E80 and ST 60 instruments with like for like.
However, the electronics installer tech in Greece has suggested that instead of having an i50 and i60 at each of the helming positions, I fit an Axiom 7 MFD at each wheel. This saves some money since two Axiom 7s are cheaper than two i50s and two i60s.
Phoned Raymarine technical support, who say that it will work ok - with three Axioms on same network.
Now wondering if this is a practical proposition? Has anyone done / considered this option. What are the pros and cons?
One pro is that yacht will then have navigation chart at each helm, as well as instrumentation. Currently I mount a 10" tablet on the aft end of cockpit table. Works OK, but is difficult to see in sunlight, vulnerable to getting bashed, and has to be moved somewhere safer in significant rain / heavy weather. (We have another RAM mount under sprayhood)
One significant con is that there will be some glass fibre work required for a different cut out configuration. Axiom 7 will not fit into current instrument display niches moulded in side decks by wheels
I would welcome any advice / thoughts on this installation.
Kind regards, Richard McLellan
