SorinCT
Hello!
I am having some issues with GPS signal and am looking for potential solutions. I have a Raymarine Axiom 7 at the helm (has internal GPS) but the GPS signal is weak and drops frequently. Some of the reasons i identified so far are: flush mount panel contains aluminum and may block signal, shading from PV array (also aluminum + stainless) and poor antenna capabilities for Axiom 7 (as per other owners feedback and tests in the local marina).
Before attempting to modify unit's location and mounting plate, i am researching what can be done in terms of externa GPS antenna. My best guess is that the coax or NMEA signal needs to get injected into the SeatalkNG network, either by a gateway or something similar. Is there any DIY solution to use non-Raymarine parts for this?
Current price for compatibe RS-150 antenna is 300 $, 60$ for SeatalkNG T-connector and backbone cable, plus shipping. 400$ to address these kind of problems is a bit too much seeing as equipment is almost new.
Network currently also has Raymarine Ray50 with internal GPS antenna, mounted at the nav console which is suffering from same issue with mostly unreliable signal.
Has anybody tried any other GPS antenna or arrangement to improve GPS signal?
