jimmy_the_builder
As part of my winter refit I replaced all the nav electronics on the boat, inc the autopilot. For this I bought the ev100-based package, which includes the the ev100 computer, the p70r controller, the acu100 control unit and a type 0.5 pump. The electrical side of the installation was v straightforward, and although I know absolutely nothing at all about hydraulics, the installation of the pump itself also seemed straightforward enough.
However, since commissioning, the autopilot doesn't work - I always get 'drive stopped' messages. The configuration is correct, and for extra confusion, the 'dockside wizard' seemed to work ok in that the autopilot was able to move the drives from hard over port to hard over starboard without problems. But out at sea, on every occasion except one, the autopilot fails with 'drive stopped'. The one occasion that it did work was (ironically) the other day when I had to limp back into port on one engine after outdrive problems caused by my bushed propellor.
I called Raymarine tech support and they suggested that assuming that all configuration settings were correct (they are) the next thing to try would be to apply 12v directly to the pump, and see if that works or not. I did that yesterday, but no sound or vibration from the pump. A further call to Raymarine confirmed that there should be some noise coming from the pump. The chap that I spoke to suggested that perhaps there might be a sticky brush in the motor.
So this morning I directly wired the pump up again (not as straightforward as it sounds, unfortunately - access is tricky), again no noise or vibration - so I whacked it (just by hand, no birmingham screwdrivers involved...) and hey presto the pump sprang into life.
Raymarine are suggesting that I need to swap the pump out for a new one. This is a major pita because (a) it is very hard to get at (b) atf will go everywhere and (c) with no atf in the power steering system the boat cannot be used. I'm obv reluctant to go down this route if I can avoid it.
So, here are the questions
1. is the problem likely to have been solved by my hitting the pump (and presumably freeing the sticky brush, if that was indeed the problem)?
2. can the motor be detached from the hydraulic pump assembly so that just the motor can be replaced, leaving the hydraulics undisturbed and the boat in commission?
3. on the hydraulics side - what do these fittings do? (these were oe, nothing to do with the pump replacement per se)
