prv
Going through the manual, it would seem that the autopilot has its own 12A fuse and it is common to power the other instruments off that.
Assuming this is a typical Raymarine Seatalk1 setup, the autopilot itself will be supplied with power from a large fuse like your 12A one, and it then powers the Seatalk bus via a 2A blade fuse inside the autopilot "brain" box. It's under the removable part of the cover where the wiring goes. If that fuse is blown then the pilot itself will still be live, but not the control head or the other instruments on the same bus.
