stuartwineberg
Got 2 of the above in my Hardy. About 400 hours, 5 years. Both engines have identical symptoms. Small pile of salt crystals in the bilge under the forward edge of the heat exchanger where it joins the end cap and white powder encrusting the joint on the underside. All running fine, temperatures normal.
I'm a bit concerned that both have identical fault. Is this a known"issue" with these engines, does it suggest a major failure is coming up, what do I do to fix it or can I let it go?
Over to the wisdom of the forum
