vyv_cox
£16m for 400KW max output?
Tidal power is the most expensive going at around 3 to 8 times cost of natural gas per generated KWH.
If I recall correctly, along with the Strangford Loch one these tidal machines are experimental, intended to build expertise and test ideas. The Ramsey Sound one appears to have been launched with only one of three turbines installed, which accounts for the projected increase in output at a later stage.
So far as additional turbulence is concerned it will be like a fart in a hurricane in Ramsey Sound.
