ghostlymoron
The traditional modern way of adjusting sails is by turning head to wind with the aid of the engine. How is this done without using the engine?
Why would you turn the engine on to do anything to the sails, unless it was because you were then heading back into harbour and wanted the engine anyway?The traditional modern way of adjusting sails is by turning head to wind with the aid of the engine. How is this done without using the engine?
When reefing in a rising wind. It is a distinct problem for those with rolling boom or in-boom mainsail reefing. I have the latter but even with an articulating luff I have difficulty reefing in a strong wind without the engine to keep head to wind.Why would you turn the engine on to do anything to the sails, unless it was because you were then heading back into harbour and wanted the engine anyway?
etc...turning head to wind ...
Now we have a boat with a fully-battened bermudan main, running in a slot up the back of the mast. The batten cars have little wheels on them, but even so they will only run smoothly when the sail is directly aft of the mast. The lazy jacks are also liable to snag the sail unless head to wind or nearly so
I know exactly what the OP is on about.....but I'd be interested to see what others have to say. Pete
I fine reach with the genoa adjusted for close hauled and let the boom out, the back wind from the genoa holds the luff clear of the mast.
However, I removed the lazy jacks, full length battens and cars at the end of the first season of ownership as the car wheels were worn and the system was just too stiff. Head to wind, which involved a series of scoops to windward, losing way, bear off and luffing again (all with the wheel locked) I could get about 1/2 to 3/4 hoist before needing the winch, now I can get full hoist on standard sliders. The main was adjusted to be used with standard battens. I have not missed the stack pack and fully battened sail and will probably not specify when I replace the main.
That's clever. I'll have to see if it works on mine.
Having to steer any particular course in order to handle the sail still feels like a backwards step from my flexible convenient gaff rig though
That's interesting as we also have no lazy jacks. We also have to raise and reef at the mast. We have always used the engine but it would be nice not to have to. I guess that could whip our main down using the back wind from the genoa but there till remains the struggle in getting the sail into some sort of order with ties, usually less of a struggle with engine on and someone at the helm.
That's why I said modern. I'm interested in ways of sail handling without resorting to the engine.It's hardly traditional. Boats have been sailing for millenia, engines have only been around for a couple of centuries. Lots of sailing boats manage fine without engines.
