stranded
A simple question I think for anyone with a mechanical mind. I've got two 100W (so very roughly 1200 x 590mm, 8kg) rigid solar panels to mount on the pushpit side rails. The connection will be through a pair of NOA rail mounts - the sort (B I think they are designated) which allow the panel to slide. I had planned to use canopy fittings to fix a strut between the lower pushpin rail and outer panel edge to prevent the NOA rail fittings turning in testing conditions. Still possible, though the rail mounts for canopy fittings all seem to have the cotter pin arranged so the strut pivots in line, whereas I would need it perpendicular) But. Is there a significant mechanical disadvantage (or indeed advantage) to using tensioned lines from the outside edges of the panel to the lower pushpit rail so as to prevent movement by 'pulling the edges in' with rope rather than pushing one edge out with a rigid strut? Does this make any sense?
