lw395
That type of antenna is usually a 5/8 wavelength whip. These are either stub tuned or coil tuned at the base. It is not advisable to hang any metal from them as it will affect the tuning. This can have the effect of a greater SWR causing power to be reflected back into the transmitter, if its too high it could lead to damage of the final transmit stages of the VHF.
Would I do it ? No is the answer as it will affect transmit / receive to a greater or lesser extent and it may just make the difference between being heard or not in the case of an emergency.
If it's a 5/8 whip, then the section of aerial parallel to the radar refelector is simply a straight conductor. So the reflelctor is at worst, a short conductor close and parallel to the antenna. Both ends of the reflector are open circuit, no part of it is grounded. It's small compared to a wavelength. The effect of it will be trivial.
Bear in mind that the bigger unknown when design a marine VHF antenna is exactly what the boat under the antenna looks like in RF terms. So the antenna is a best guess compromise. Hopefully, it's optimised to be OK with anything from a steel ground plate to a random lump of plastic under it. Unlike some serious antennas which are tuned to account for the ship or vehicle that is under them.
