caiman
Hi
There are a couple of threads on the forum at the moment concerning PLB's.Can somebody please clarify for me,'Can radio signals such as emitted from a submerged PLB, transmit to a recieving station above the surface, from underwater?'In other words,if you set off your PLB from it's belt pouch on your LJ whilst in the water,will the signal be recieved while the pouch is under the surface?I am willing ,and wanting, to be corrected,but I thought that, if say a submarine wished to transmit to a recieving station above the waves,then it would have to transmit to a bouy with an aerial sticking out under the water,connected to an aerial sticking out into the air,to relay to surface recieving aerials?
This is not just about PLB's.For instance,can you radio control a submerged ROV from aboard a boat, without the transmitting aerial penetrating the surface of the water?
Thanks for any input.
Cheers
Cheers
