john_morris_uk
Just to be really picky, you only need one QQVO6-40 to run push pull. It’s a twin tetrode within one envelope. (I used to use them!)SWR (standing wave ratio) is not particularly important for reception so a radio will receive with almost any wire or wet string poked in the back. Where it falls down is transmitting into the same antenna which is why only a transmitted "radio check" will verify all is well. Except most people do it on full power to a local station which is fairly pointless for the reasons above.
I don't go around routinely testing all bits of equipment I use in my daily life so I don't understand the fascination with radio checks. With solid state gear, it shouldn't be necessary but possible if you're still running a set that uses a pair of Mullard QQV06-40As in push-pull config, then maybe. Once you'd warmed the valves up
