PaulRainbow
Thanks so much you two.
That kit looks so much more compatible. Looks like power supply into the white, yellow into the back of the ST4000+. I assume I will need another cable to connect the Element9 plotter into the other white socket?
Correct, but note comments above regarding power, do not connect the power cable if the converter gets power from the Seatalk device it's connected to.
Yes, you will need a STNG spur cable to connect the Axiom.
