MarkJohnson12345
Ref an earlier post of mine about a Furuno 1722 radar that was just showing concentric rings on the screen, fault has now been found.
To add to the knowledge base, the problem was that the belt that turns the scanner had come off the motor.
Thus the radar was working but only pointing in one direction. I have spoken to Jim at Furuno who was very helpful, he said that the scanner must have stopped over the magnetic block that detects the scanner rotation. If it had stopped elsewhere an error message would have been generated.
Only reason that the belt could have slipped off was that the motor/cog that drives the belt to the scanner might have slipped a little. Its fixed by a grub/ alan screw that is normally rock tight.
So good news, just off back up the mast......................
