pandos
After 5 years of non use ominous noises from the antenna, I presume a bit of creaking in the works as the antenna rotates in the dome.
Question? should I ignore and allow it to free itself out, or should I send someone up the mast with a can of silicone/wd 40. drill a tiny hole in casing, spray it in.
It appears to function fine but in a yard with surrounding hills so difficult to be sure.
Regards.
Regards.
