nigelmercier
RIP
- Joined
- 20 Jun 2007
- Messages
- 16,234
- Location
- Live in Kent, boat in Canary Islands
ASAP have just sent me an article about fuel filters in which they are offering a discount on the Racor 120AT Diesel Fuel Filter:
I have been meaning to upgrade my filter, and now seems a good time.
A recent email from Parker-Racor technical department highlighted a problem that I have found: "I have searched the web for the fuel flow rate of the Volvo MD22P-B but can’t find a definite answer on what it should be so If you can advise the flow rate then we will be able to advise a suitable Racor unit to do the job..."
I'm also unsure if the screw fittings on this filter are correct, Volvo Penta told me: The four entries/exits on top refer to ¼” – 18 NTPF, but they are unable to give any more data.
Where can I find out the fuel flow rate, and if this filter is suitable?
- Maximum Flow Rate: 57 LPH
- Port Size: 1/4"
- Element: 10 Micron
- Height: 166mm
- Width: 81mm
- Depth: 81mm
- Bowl Water Capacity: 52ml
