Racor 500FGSS fuel filter
TonyBuckley
15 May 2006
Boat is in Brighton Marina
www.icloud.com
Hi,
I want to change the filter on my primary fuel filter which is a Racor as I have no idea how long since last change.
What's the appropriate micron value filter I should get?
How would I tell what is currently fitted - would it be stamped somewhere.
Found some instructions and sounds very easy to change. Seen posts saying no engine bleeding required - is that true?
Thx.
The micron size will be on the filter itself (and they are a different colour) but not the external housing as the 500 will take all 3 options.
The different micron ratings all have their advocates. 10 micron is the most popular followed by 30 with 2 the least popular.
If you fill the filter up with deisel most engines will start without bleeding, but some stumble a need restarting a couple times others are very sensitive to air and need bleeding.
You should learn how to bleed the engine anyway.
I know how to bleed - that's the first thing I picked up on and prob the only thing I could do enroute. But a pain as have to remove cockpit stairs, remove engine casing and lift it (it is heavy) onto the sink area. It makes the difference of a 10 min job to an hour as the lift pump does not lift much per press.
A local chap says don't bother with pouring in clean diesel, just open tank tap and be quick so when full screw the lid on.
I like that the micron identity is colour coded - found that on web now. Think I will go for 20 on a 30hp engine.
Thanks to all for replying.
A lot of boat manufactures don't make routine jobs easy so I have some sympathy, but it it takes an hour to bleed I would make some changes.
An electric, or squeeze, pump can be placed I a convenient location. This will replace activating the lift pump. Maybe a small hatch so you can reach the bleed screw on the secondary filter.
If this is not possible I would fit dual primary filters that can be switched with the flick of a lever. That way with a clogged primary filter can be changed without bleeding.
Even if you can change the primary filter in the marina without bleeding there is no guarantee that with a heeling bouncing boat that some bleeding will not be required.
An hour to do this basic task is too long.
I had the pleasure of changing the filter today and it was a joy.
For others who may stumble on this thread via a search, here's the routine I went through.
1: Turned off fuel at the tank.
2: Unscrewed the top of the filter and removed top (mine was very accessible).
3: Pulled out old filter with the handles.
4: Slotted in the new one (30 micron red).
5: Put lid back on, but not tighten screw.
6: Turned on tank fuel tap.
7: When diesel flows onto the outside of the top, screw up tight.
8: Ease knob on the bottom of the jar and release water (didn't have any) and crud.
9: Retighten knob.
Ran engine for 30 mins with no problem; no bleeding required and I reckon that should be long enough.
Glad I did, the old filter was amazingly black and filthy.
Not often that a boat job is so easy and quick. I know this sounds trivial, but on the old boat, it was an utter pain. The Racor is a good bit of kit!
Tony
