Racers stand down
I have to adjust the rope/tube thingie every time i put up my sun shade other wise it stops the boom thingie going up! Whats it for anyway?/forums/images/icons/smile.gif
<hr width=100% size=1>
Not as often as I should (it's on a clam cleat at the mast base), but then again I rarely seem to have any free wind these days - could this be my age?
I'm going to fit a deck organiser on the port side to match the one to stbd and bring reefing lines and kicker back to t'cockpit. Winter job!
Re: On the fiddle
I have a gas jobbie and adjust for every point of sail. Praps I should just leave it well alone but then I'd feel intimidated by the cackling of purists as I pass them - or vice versa :-)
I adjust mine all the time, I have a spring loaded type and you have to pull in the rope & tackle everytime I put up the sail or reef, also release it a bit in light winds.
<hr width=100% size=1>dickh
I'd rather be sailing... :-) /forums/images/icons/smile.gif
I keep thinking about adjusting ours but then get sidetracked on to some other thoughts such as a cold beer ! On a cruising boat though would it make much difference unless it is well 'out' ?
If I don't ease off the kicker when hoisting the main it is a bugger to get up, let alone anything approaching tension in it. Maybe I should fit a halyard winch.
I'm afraid I use it all the time. Not so much on a close haul as the mainsheet does the job of it , but when reaching and running it's always being fiddled with.
Why should I? The boat was delivered like that, so obviously that is what the manufacturer intended.
Re: Don\'t you?
I adjust it frequently - abd always tighten it up when the boom starts to lft on a run. Not bad for a diehard cruiser.
Yes yes, I agree with this. I usually pul quite a few strings when going quite fast. Then the boat slows down a bit, which may have been the wind, maybe not, so then try (and fail) re-adjusting everything to as it was when going fast, when i should have left it alone.
Re: Don\'t you?
When I was a callow youf the kicker was always played. Now I'm an immature adult, I find that close hauled the mainsheet and traveller do all the work, so I can leave the kicker sufficiently floppy that when I come off the wind the boom lifts to tighten it to the point where I don't need to adjust it. Nirvana.
<hr width=100% size=1><A target="_blank" HREF=http://www.writeforweb.com/twister1>Let's Twist Again</A>
Re: Kickers
Must say I thought last week was a really good example of the trivialisation of the news agenda.
Major stories:
Beckham in Japan
Harry Potter
The Bent Bishop
Will Victoria like Madrid
Prince Willy's birthday
Twice
April when we go in and November when we come out.
Three times this year actually - Jimi fiddled with it and it seemed to make quite difference really - but he wouldn't tell me what he did.
<hr width=100% size=1>regards
Claymore
As frequently as changes in wind conditions dictate to keep the best possible mainsail shape. Just because one's a cruiser it doesn't mean one should accept sailing with low efficiency!
Indeed it doesn't - we only measure out enough water per cup per person each time we brew up. Hows that for efficiency savings on Gas and Water?
I once spent a week cruising with someone who constantly fiddled with every damned sheet and control line on the boat - it became a source of irritation which led to his never being asked back
Claymore
