KellysEye
>Captain Tolleys Crack Cure might do it,
I used that successfully, its worth a try.
Get a blunt knife and a thin piece of rag and slip it
Between the window and rubber so to clear any
Dirt out and then blow any water out with a bit of
Tube then just seal with some clear Geocel Marine sealant
Or similar with a thin nozzle, job done.
If it's just one window at the moment, I would just replace the rubber strip on that one now and then do the rest next spring. It doesn't take long to do and will be more succesful than sealant/vaseline/captain tolley. You can get rubber strip from Seals direct. I glue the strips to make a complete ring which I think does a better job using superglue.
I still feel that carrying out a proper repair is likely to take less time in the long run than messing around with sealants that may not work. You only need a few hours dry weather to do the one that leaks.It's a job for the spring and a dry sunnny day.
It took me half a morning for my first attempt on my Vega's cabin windows; the second one was far quicker at around an hour.
The smaller forward windows are a pain beacuse of the tight radius and are more awkward than the cabin's.
Thanks for all the replies. Alistair, you're spot on about the location of the leak. I'm currently sitting aboard hoping for another rain shower to pass so I can see if the gunk I slathered all over the window a minute ago will make any difference. I couldn't find the big tub of vaseline I carry for such occasions so resorted to using some heavy grease. I have a piece of canvas rigged up as an ineffectual shield so that will hopefully stop the rain from washing the grease away too quickly.
Now all I need is someone to tell me that the grease will eat the rubber...
