rhinorhino
Am I missing something in this month's question of seamanship? The answer seems to be quite wrong.
Ignoring the photograph which shows a channel with enough room to pass a supertanker, the question is this; you are tacking up a narrow channel, a coaster (which you haven't seen till then) signals from close astern that it doesn't understand your intentions (5 short blasts) what do you do?
Suggested answer is bear away back down the channel.
Several thoughts occur; you are stand on vessel (assuming you both must remain in the channel for reasons of draft, coaster (as passing vessel) should keep clear.
If there is room for you to pass him going down the channel there is room for him to pass you going up. If not where are you going to bear away to? To bear away will put you right across his bows.
Am I missing it?
Am I missing it?
