Jcorstorphine
I have set up a circulation system to pump a 50% solution of Rydlyme solution through the water jackets of my 2.5 HP outboard using a small submersible pump attached to the inlet cooling pipe (with the lower leg removed). See this video.
https://flic.kr/p/U1RGJK
My question is how long to keep running the solution as after about an hour it is still fizzing away.and if I drop some solution onto the concrete, it is still pretty reactive. My worry is that I damage the water jackets as some references would suggest that after only about 15 mins the reaction stops.
