Question about early model Rotostays
Poignard
23 Jul 2005
South London
If anyone has a length of early model Rotostay foil handy I would be very grateful to know the diameter of the groove into which the headsail luff rope slides;
Thanks for that.
The reason I want to know is because I am going to fit a genoa with Reef Rite Kiwi slides (slugs) and I need to know the maximum diameter of slide the foil will accomodate since Reef Rite say to use the largest diameter Kiwi slide that will fit into the groove.
Thanks for that.
As I said, it probably depends on the model of Rotostay. Can't you check the groove size on yours by pushing different diameter bits of rope into it?
Unfortunately, my boat is in Brittany at present and I am in London.
However, I do have a short length of scrap Rotostay foil here which which has a groove diameter of 3/8" (9.5mm) but I cannot be absolutely sure it is the same as I have fitted to my boat.
I also have my genoa here and the diameter of its luff rope is 8mm.
Kiwi slides/slugs are available in 8mm and 9mm diameters.
The manufacturer recommends using the largest size slug that will fit into the foil.
That would be 9mm, provided the groove diameter on the foil fitted to my boat is the same as that of the scrap piece I have.
That is what I am unsure of and why I asked if anyone else had access to a foil they could measure.
These slides are coming from New Zealand and I expect the postage will be high so I don't want to order the wrong size and have to send them back.
OK, that's a bit clearer. I'd order 8mm, as you know they'll fit, just the same as your genoa. They're unlikely to pull out.
Thank you. Lots of fervent government-haters would disagree with you!
Myabe they would.
Personally, I operate a strict policy of compartmentalization on this forum.
I might loathe and despise a Brexiteer, for example, but if he wanted to buy something I was offering on the 'For Sale' forum I would have no qualms about dealing with him; and I would try to be the epitome of courtesy (although I might make sure I had the money before I posted the goods!)
Mind you, few of our resident Brexiteers seem to have much involvement with sailing!
I suppose the level-headed, cerebral, calm, self-disciplined, tolerant, mature types who skipper yachts are unlikely to see any merit in leaving the EU. ;)
I have a Rotostay FS-E, here's a picture of the bolt rope groove swallowing a 10mm drill [it won't swallow a 10.5], and the slot gap is 3.5mm
Interesting.
Was that a successful modification?
Yes - it was a nice sail and lived out it's life hoisted on my Rotostay. There was no UV strip so I tended to take it down when leaving the boat - the slides made that easy. The slides were supposed to be for a mainsail, but I fitted them instead of the piston hanks using a few turns of light polyester line.
8mm is fine for older Rotostay...So long as it’s not the rare twin groove version .
Have seen the plastimo slugs used as well(6mm ) .
Kiwi slides are better as they allow for a tighter furl to the foil,
Do you keep a stock of Kiwi slides?
The reason I ask is that I have had a quote from the manufacturers in New Zealand and although the slides are not expensive in New Zealand, the shipping and bank charges are disproportionate when buying a small quantity and having them sent to the UK;
13 Kiwi slides NZ$ 65.78
Bank charges 30.00
Post/packing/insurance 81.39
Total NZ$ 177.17 which is about £88 sterling
On top of that my bank will charge £25 for the money transfer!
It seems a lot to pay for a piece of nylon with a bit of webbing bonded in.
Bank charges 30.00
Hi that sounds a bit steep .
We can order them from Bainbridge I think. Don’t believe they were that expensive.Will check in the morning for you .
Thanks. I appreciate that.
I don't think ReefRite are interested in retail sales. 2020 and they won't even accept payment by credit card.
