vas
OK, that's a tricky one, bear with me!
yanmar 2GM20F decided it's had enough and wont start after only 1000h. Was difficult to start and had low compression for the last couple of years at least.
Said engine runs a 3000rpm generator so governor stuck to almost WOT all the time. Engineer said it's typical issue stuck rings.
Indeed removed all paraphernalia, as well as cyl.head cylinders are nice and smooth, no probs, valves/seats almost perfect, so stuck rings it probably is.
Assembly is on a reasonably difficult spot against the e/r to lazarette bulkhead with decent access on three sides, and just 80mm from the top!!!
Was worried how I'm going to handle the motor/generator combo and how I'm going to take them apart, but on closer look, the U-shaped frame running under the combo has an extra bracket where the generator is bolted on. Engine has 4 mounts to this frame and the elastic mounts are between the frame and the tray it's bolted on.
So simple job to undo the four yanmar mounts, undo the 8 M8 bolts that hold the MD35 (I guess it's some sort of ISO standard thing...) to the motor and slide the yanmar out keeping the generator secured on the frame.
Alas, not that easy, I mean I have an easy 2mm all around, a bit of hammering or fitting a massive flathead screwdriver and trying to lever shows that things are somehow connected...
Now, before removing the 4 M8 (or smaller) bolts that hold the generator casing to the MD35 interface and taking all things apart with dubious results in terms of putting it back together... anyone familiar with this thing???
A few pics from today:
and a link to online drawings of the generator MR2 and the MD35 interface:
https://www.hsaoy.com/2.4_Generaattorit/2.4.1_Meccalte/mr2.html (bottom of page inset is the MD35 which doesn't look good...)
Now looking at generator x-rays online it seems that the rotor shaft has a woodruff key, so in theory I'd expect that to slide out.
However, on the MD35 interface, there's clearly a disk plate engaging to engine. SAE 5 is mentioned and disk dia of 314.3mm is shown.
Mind I haven't the faintest idea of how the outlet side of the yanmar looks like. For sure there's no "clutch" as such as it's always mated to the generator.
On the pics you can see a biggish cylindrical piece lightly rusted, smooth all around, no key on it (I think I did a whole rotation of the crank!) so no outside access.
I'm worried that once I try and remove the generator I'll have to take the whole thing apart and remove the back side and the stator and end up with the rotor mounted on the crankshaft...
Anyone knows if that's the idea of taking these things apart, and if so anything I should take care of when doing it?
cheers
V.
cheers
V.
