simonfraser
am i worrying too much here ?
there does not apear to be a temp sensor for the exhaust gasses on most turbo diesels. mine KAD44 EDC
if there is a cooling problem the engine is going to suffer major damage b4 this is noticed, correct ?
i am about to fit an alarm on my bilge pump, but will this go off in time to prevent engine damage if i have a water cooling leak into the bilge ?
obviously wont go off it there is a loss of flow, so still a problem.
a pyrometer EGT has to be fitted to the exhaust pipe, of the engine b4 it enters the turbo.
this requires the part to be removed, hole drilled and a suitable nut to be fixed on the exhause pipe.
is this all worth it ?
