skyflyer
I didnt think this though!
Bought a solar panel assuming that it would have a simple two core cable that I would route through the coachroof to the controller thence the batteries.
Of course it doesnt have a simple two core cable it has two single core cables with connectors on each end, which I now realise is designed to allow connection in series to other panels. I'm only using one panel, so these are my positive and negative cables, correct?
They're pretty thick and look as though they cant be bent to a tight radius without permanent kinking, is this OK to do or should it be avoided? I have no idea how the inner core is constructed.
The moulded plugs are going to need big holes in the coachroof, so i am minded to try and find some sort of waterproof connector into which they will plug, which can be mounted on the coachroof and then back to my original plan of a smaller pair of cables to route through to the controller.
Can anyone recommend a dedicated or adapted product to do this?
