Enya
The oil is mineral based, not semi synthetic.
Suggest you re read the OPEnya,
Are you sure that using semi-synthetic is the correct oil to use. What engine do you have? This is important for advise on the effect.
I would not advise mixing mineral with semi-synthetic.
Check your manual and put in the correct oil if semi-synthetic is specified. The cost of the mineral oil you may have to remove and waste is small.
I have read the OP several times. Please explain !
My reading of the OP is that mineral has been put in instead of semi-synthetic. So where am I going wrong? Perhaps the OP is ambiguous.
Sailing my Albin Vega, often singlehanded, mainly in the Solent. Maintaining the Boat.
I'm not alone here reading this thread and we are all confused by your replies and we are trying to help the OP with his question.
Treat it as if you have used it as a "Flushing Oil" and change it.
Why? I don't think I know any oils that are exclusively for gasoline or diesel engines. Even traditional gasoline oils, such as Shell X100 are also rated for diesels, as VicS says, with the prefix 'C' in the API spec.
Dont worry sleep easylSorry I have been out on my boat and incommunicado. The story is this. I went into Sainsburys garage last autumn and bought 5 ltr of mineral oil (not semi-synthetic) for the BZ 482 on my boat. Changed oil before end of season and thought no more. A few weeks ago I needed to top up my car oil which is actually petrol and reading the label noticed it was for petrol engines. They also sell oil for diesel engines as I have since noticed. Having used up all of the oil on my car, it was low, I threw away the container. I therefore cannot answer many of the questions about the spec. The engine seems to function very well with the oil and it still looks nice and clean but should I worry? Should I top up, if I need to with the same make of oil or should I use oil for diesels?
